Frågor och Tips ⇒ Zumo 660, software version 4.10
Leif#2000
Inlägg av Leif#2000 »
Hej på er,
Software version 4.10 finns för nerladdning.
Ska innehålla följande:
Changes made from version 4.00 to 4.10:
Fixed a problem where the volume of navigation voice prompts was not consistent.
Fixed an issue where the preferred road name was not used for the navigation voice prompt.
Fixed inconsistency between navigation voice volumes when the Master and Media Volume are set to 100%.
Increased the volume of proximity alarms transmitted over Bluetooth or analog headsets.
Fixed a display problem in the music volume screen.
Fixed a problem where the unit appeared to hang on startup while loading maps.
Jag hade problemet med att volymen på instruktionerna skiftade i styrka, det skulle nu vara fixat.
Leif Skipper
VRS #2000
