In order to correctly perform the Bluetooth connection to the N-Com system, the Garmin Zumo navigator must be updated with the software version 2.50 or higher. If the software is not updated, download the latest version from the Garmin website (
http://www.garmin.com/support/download_ ... sp?id=1907).
CAUTION: the navigator software's updating is required with version 3.30 in case version 3.20 is set up.
When first using the navigator, perform the Bluetooth pair-up between the N-Com and Garmin Zumo using the Handsfree (HF) profile, according to the following procedure:
Warning: When pairing up the navigator to the N-Com Bluetooth Kit system, check the correct use of the pairing up HF (Handsfree) profile. With the N-Com Bluetooth Kit2 or Bluetooth Kit X-Series systems, the pairing up profile is automatically chosen by the system.
* On the navigator select the Bluetooth icon from the settings menu and check whether it is active. If required, activate it.
* On the N-Com e-box keep the button ”œon” pressed: the volume buttons first light up and after a few seconds start flashing;
* Select ”œConnect headset Search” from the Bluetooth menu. When ”œAdd device” appears, press OK.
* The navigator performs the search and finds N-Com;
* Perform the audio test. N-Com will be recognized by the navigator as its headset.
Once the N-Com and Garmin Zumo are on, the search is automatic and the voice messages (or music) are sent to the helmet. During the Garmin Zumo communication, the intercom via cable is automatically interrupted and then restored at the end of the communication.
Some mobile phone models*** allow the Bluetooth connection to Garmin Zumo. Perform the pair-up and the connection between the Garmin Zumo and the telephone according to the instructions provided in the Garmin Zumo manual or on the website. If the Garmin Zumo has been previously paired-up and connected to the N-Com Bluetooth system, the call goes straight through the helmet.
